Discuss Fernox jointing compound for potable water? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Hi guys, i would really like some advice. Do you guys use PTFE tape to make your brass connections to a cylinder? Or is there a jointing compound that can be used?
I filled up a horizontal cylinder today just before finishing off for the day and then get a weep on the cold feed. So had to drain down and leave until am back there on wednesday.
I never get this problem with hawk white while working on iron barrel.
Any advice would be great. Thanks
Lee
Hi i use PTFE tape on my cylinder connections. just wrap it round a load of times. i know a guy who says he only uses boss white.
Whatever you find works for you.
Reply to Fernox jointing compound for potable water? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes, it me again. I have a leaking compression joint that is connected to plastic pipe. I have now read elsewhere that it is not a good idea to...
2K
Hi This is my first post as a homeowner/DIYer Hopefully the title explains my question ; I want to replace the washer on an Essex flange as the...
2K
Forgive my ignorance. I was performing a test of a new manifold today, using mains water pressure to the 22mm flow pipe and back through the...
3K
This maybe isn't so much about asking for advice as giving it 🤔 I had a leaking HW cylinder (23 years old) that I got fed up patching up with...
2K
Not sure if this is a success or a fail or just a rant but We do have heat and hot water now So all started the evening of Friday the 12th (Nov)...
2K
