Discuss Extractor fan pumping down underfloor ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
on31ll
Can this be done ? Cant go any other way ! Its a under-staires toilet ? Can i go down under the floor with rigid ducting and to a air brick outside ? Its only a toilet and a sink in there !
Dont forget to fit another vent other side high level to get cross ventilation i would do it in my own house if i had to
its possible, im assuming your fitting the fan at high level and running ducting down boxing/inside a wall? you may have to keep the duct falling away to the vent grill as you will probably get condensation build up inside. Insulated ducting would help this.
you could consider a false ceiling? ducting into floor above?
Its understairs ! With the positions i could only vent down a stud wall that will be built ! Ill keep thinking about it ! Thanks guys
Reply to Extractor fan pumping down underfloor ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A close relative has moved to a new property and there is a small ground floor toilet room with a non working extractor fan fitted to the ceiling. The make of the fan is "Sector" and when removing the cover it has two time settings I am guessing for how long the fan stays on after switch off...
Hello I have a mystery, my bathroom has a sewage smell appears to get far worse 5pm-9pm. I have plugged my bathroom/sink with plugs and its 100% coming from the toilet. Tried Lugi worlds best plunger, that air gun blaster and 50 buckets of hot water down the toilet for 2-3 days and no joy, the...
T
Morning, Im in a top floor tenement flat with access to the attic space. I have a combi boiler with flue that emits vertically up through the roof. My kitchen is situated internally with no easy access to an external wall. Could I fit a kitchen extractor that ducts vertically then right angles...
I have a vanity basin and concealed cistern toilet to install. In place if a wall hung basin and toilet in a down stairs cloak room. The only problem is it's a tiled floor and the original toilet has been fit then tiled around. So when I remove they'll be a hole in the floor tiling. The new...
Hi all. Not sure if it's a plumbers job or another trade but thought I'd ask. I am installing a new toilet downstairs next to an outside wall. There is a 3 way inspection/access chamber about 1.5 metres outside this point which I plan on going into. It has one inlet in use from the upstairs WC...
