Discuss Emersion heater install in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
T
Tash Jan
I am fitting a 80 lt back up emersion, flat tank it's back up while I interview the existing gas boiler, mechanically not gas wise. I only have 14 mm pipes up stairs the run to shower is 2m for hot and cold pipes. There is no chance to fit a larger supply pipe. I am aware of press reduction Vale and temp control valve requirements and the required circuit. My q is should I run 20mm from 14mm at Bath, shower supply to the emersion or will the 14mm be OK it's to shower while boiler in bits
What’s the feed pipe(size) to the immersion?
Reply to Emersion heater install in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
