Discuss dripping tap on bathroom sink i in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The gotcha is that it is a tap and sink is in China, though it was bought at B&Q there.
B&Q closed in China a few years ago. I thought I might be able to replace the 'cartridge' (is that what it's called?) with one bought here in the UK, and take it with me on my next trip. I had someone send me photos, but I can't find anything like that at B&Q or in Google searches.
The alternative is to replace the whole tap, but the B&Q guy I spoke to said that the holes in sinks in the UK are typically (I think he said) 15cm apart, and it seems like the holes in our taps are more like 12cm apart (centre-2-centre). Visually, they look 'narrower' too.
I guess we might end up trying to find the cartridge in China, and/or replace the whole tap with one sourced there.
I wonder if anyone has any thoughts on this, and perhaps some way of sourcing the parts here.
The taps look like this:
https://photos.app.goo.gl/i6Cn3Vuzkf3NAGvCA
and the cartridge:
https://photos.app.goo.gl/chGcdKR9HTJWWYWo8
What do you think?
Max.
Have to confess that, as many as Ive seen, I've never seen the likes of that. Sorry
Same here and my guess is that Dave's seen many thousands more cartridges than I have.
I'd be looking at new taps with easily replaceable parts, you could get really lucky and find what you need but you'll probably pay through the nose for it and you'll also probably have to go through the same thing in about 5 years.
Knowing the price & choices avail in China, personally I'd simply replace with individual taps & blank the centre hole.
Thanks guys. It does sound like this isn't something you find in the UK - the tap nor the cartridge - so it is only something I'd find in China. Since it is in China, I might as well just resign myself to attempting to find the parts and/or replacement tap there too.
BTW, there is no 'centre hole' (afaik) - there is a hole for each of hot and cold, and those holes are closer together than what seems 'normal' (if it isn't an actual standard) in the UK.
Thanks for clearing that up for me :D
Eh? That isn't what it is, but I suppose it could be replaced by two taps.
...well, I don't *think* it is supplied through a single hole in the middle, but I'm not there right now. It's quite possible I'm wrong about that.
In the absence of xray vision, one can only suggest alternatives ;)
Indeed, I guess I could get someone to take some photos from underneath, but there isn't much point, I think, since the general conclusion seems sound to me - ie that it makes more sense to try to find the bits in China.
Thanks to all.
TBH, in my experience, that is your only choice. Good luck.
Reply to dripping tap on bathroom sink i in the Plumbing Jobs | The Job-board area at PlumbersForums.net
This is probably obvious but I want to replace the cartridge to stop dripping. I have done similar before but I cannot work out how to remove the...
I have a wall mounted bathroom tap that leaks. Presumably I need a washer of sorts replaced. I cannot work out which tool I need to remove the...
my bathroom sink (installed 2017) was broken recently and needs replacing. on inspection there is no brand name and only a few markings so I'm...
I have quarter turn taps in my downstairs bathroom, the sink taps were getting a bit stiff so I replaced the insides with Flomasta 1/2" BSP...
Hi Can anyone identify the make and model of these taps please? We have one dripping bathroom sink tap but the plumber we had couldn't find a way...
