Discuss I have a leaking wall mounted bathroom tap in the DIY Plumbing Forum area at PlumbersForums.net
I have a wall mounted bathroom tap that leaks. Presumably I need a washer of sorts replaced. I cannot work out which tool I need to remove the tap. There is a small hole (8mm?) to the side but I can’t seem to get a fixing from either a alum key or screwdriver. Ever hopeful…?
Matt
Yeah can you post a photo and tell us the make?
Reply to I have a leaking wall mounted bathroom tap in the DIY Plumbing Forum area at PlumbersForums.net
