Discuss Dripping tap ceramic disk cartridge. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Matt0029
Do many of you try getting a new ceramic disk cartridge for a dripping tap. Or just fit a new tap. I know getting a new cartridge unless a recognised make like bristan etc can be hard to impossible. What are your thoughts on this?
Screwfix do some cheapo ones , I stock those and if they dont fit , its a new tap
I see it's the spline length and number of teeth to look out for. What do they class as the spline on these?
Splines are classed as the ridged parts, but not bloody easy to count! Which spline do you start with - and then how can you be sure where to end? :p
Personally I buy Screwfix ceramic works as they are very reasonable cost for the pair and do fit some taps. B&Q also do a few different sets.
I just take the tap head off and see if some of my stock works fit it
Depends cheap tap I just change the tap but branded one then I might change the cartridge
That's why I invented what I did Matt :D
Differences in cartridges are:
- opening direction (clockwise or anti)
- dia of spindle (splined bit - 7.5, 7.6, 8.0, 9.0, 10.0mm)
- number of splines range from (15-56)
- splined length (5-12mm)
- height of spindle (22-120mm)
- whether it's threaded for a shroud (yes or no)
- depth of seat (inside depth of tap 1/2" from 21 - 26mm, 3/4" 20 - 27mm)
There are more, but calculate the above & it works out at around 1,000,000 permutations. Reality tho is around 2000 so far found for 1/2"...
Tap Magician do indeed do a wide range of Chinese options.
Just be aware tho none are WRAS (or equiv) approved so installer shoulders complete legal responsibility when installing as clearly breaching water regs.
Law says it's not illegal to supply - only to fit :eek:
Reply to Dripping tap ceramic disk cartridge. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
