Discuss Dripping tap. Can’t access cartridge. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have a dripping bath tap. Seperate to the spout. Quarter turn level tap from the wall.
I need to change the cartridge as it’s dripping lots but can’t seem to work out how to remove the housing. Has this been installed badly behind the tiles?
In the second picture it looks like there are threads in the chrome part where it meets the brass valve body.
I'd say the chrome part will unscrew, revealing a nut on the cartridge, it may need the tile grout scraping away from it first.
Caution where actually unscrewing the cartridge in case the body isn't fixed to the backing, the pipework may move leaving you with a hidden leak.
Thank you.
Reply to Dripping tap. Can’t access cartridge. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
This is probably obvious but I want to replace the cartridge to stop dripping. I have done similar before but I cannot work out how to remove the...
I have attached an image of a kitchen tap which requires the housing around the cartridge to be removed. The housing is much more than hand-tight...
Hi, I can’t get one cartridge to budge when trying to replace in a mixer tap. The hot side cartridge was tight but removed with wrench...
Hi all. Just had a neighbour knock the door regarding a water hammer issue. My own house developed this issue sometime last year as well which is...
Hi everyone, I recently had a Hansgrohe wall mounted single lever basin tap and a Hansgrohe thermostatic concealed bath/shower valve installed...
