Discuss Drayton motorised valve in the DIY Plumbing Forum area at PlumbersForums.net
I'm needing to replace a Drayton Mid Position valve Actuator, code MA1. The failed one is 3-wire (red, green, black) but all the new ones I've found advertised are 5-wire (yet the cover data plates are identical!).
Question is - can I replace the 3-wire actuator with a 5-wire, and if so how should I wire it? Or are 3-wire versions available?
Thanks!
Are you sure the installer hasn’t just chopped the wires off
No, that's not the case, as can be seen in the photo...
3 wire is a diverter eg Drayton 27102
Pn 27652
Reply to Drayton motorised valve in the DIY Plumbing Forum area at PlumbersForums.net
Hi I have a fully pumped heating system fitted with a Drayton MA1 diverter, after the summer run the heating stopped coming on, so I replaced the...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
Hi, i am replacing a 2 port z5 drayton valve with a 3 port mid position drayton. Can anyone please tell me what changes i have to make to the...
Deleted member 120897
I have tried hard to get similar to the first class satchwqell /Sunvic SML type revolving type valves instead of the quite short lived spring...
