Discuss Draining conventional system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Andrew Robertson
Having to clean a system prior to fitting a new heat only boiler but the customer has fitted a new floor and not left access to the pump or zone-valve.
Is there a way of draining the system without manually latching the valve open?
Could I just run the old boiler with heating on and drain it at the same time?
Cheers
It'll be possible to send an electrical signal to the zone valve causing it to open independently of the boiler. How easy it will be will depend on how the system has been wired. You'll need to provide a lot more details or consult an electrician if your knowledge of electrical work is not up to scratch.
My advice, however, is not to do anything to the system until the owner has restored access to the pump and valve. Or, at least agreed in writing that he accepts that you are likely to need to gain access and any damage to his floor will need to be made good at his expense.
Cheers
TBF, you sound a bit like one of the others :)
Why would you even contemplate fitting a boiler where you have no access to valve or pump? Commissioning will be a nightmare
That's why I was asking if there was a way of opening it. Luckily I have access to the motorised valve (only to latch it open) but I prefer to change them/the pump when installing on a system that's as old as it is.
Reply to Draining conventional system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
During an install of new boiler ('old' boiler died after 11-12 years) the system was "drained" but I guess maybe 90% of water was left in the...
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
F
Does adaptor exist? Hi, looking to move a rad, the original valves will be hidden behind a bath, so I was wanting to leave original valves in...
