Discuss Moving rad without draining down. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
F
Freetronk
Does adaptor exist?
Hi, looking to move a rad, the original valves will be hidden behind a bath, so I was wanting to leave original valves in place so no need to drain down, connect a run of 15mm pipe connecting to its new position. What size connector would fit on old rad valves that would connect to 15mm pipe?
Steve
This sounds very silly, just do it properly- you need access to the valves .
It’s not a big/expensive job if you don’t fancy it, just get a plumber in.
Reply to Moving rad without draining down. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
