Discuss Double boilers oil modulating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
semitar
Hello,
I have ideal which I would like to share and gather your thoughts.
My current system comprises of a hot water storage tank and a Camry 25/32 utility boiler (oil). The boiler is fitted with a 0.75 nozzle.
The house is kept at a constant 21 degrees right throughout the year (aged parents). According to the Sebek calculator I need a boiler capacity of 21kw. My current boiler is set for 27.5kw.
It seems crazy to run a 25/32 utility when the house is up to temperature, short cycling etc and there’s currently little in the way of modulating oil boilers.
I have a brand new Camay 12kw utility (0.5 nozzle) in the shed. I am thinking of plumbing this in parallel with the 27.5kw and when the main room stat hit say, 18 degrees switch over to the 12kw boiler which would run the rads and hot water. If the temperature drops below 18degrees then the main system boiler would switch on instead of the secondary boiler.
The benefits of this would be a reduction in oil usage once the house hits 18 degrees and secondary redundancy should one boiler fail.
What do you think?
Reply to Double boilers oil modulating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
I currently have a Vaillant ecoTEC Plus 438 system boiler which is 13 years old. I have been having problems with the boiler which potentially...
We are experiencing an issue with CH short cycling on a Worcester Bosch Greenstar 25i ErP boiler. From a cold start the boiler fires for only ~25...
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know...
