Discuss Donut washers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mfgs
What donut washers do you guys find best. Also are there bigger ones available for the old 2 1/4 inch cistern holes?
depends old pans the rubber ones
ae235
but flat bit down to pan as more surface area and better squeeze unless there's a special indent for radius bit
newish ones
and get a donut for a 2" will stretch 1/4"
I seem to struggle to get a good seal with the standard donuts on the bigger 2 1/4 inch outlets. Although I have only ever done two, both have been a nightmare to get to seal with a standard donut.
I hate myself but i smear clearfix on doughnuts now and never had one leak since. Had to many of the dreaded wet finger on a late evening jobs.
I find if the cistern seems to stay up off the pan because the donut washer is clearly hitting solid, then those seals will not leak.
It is the loos where the cistern and pan china hit together that are more likely to leak.
If find the bigger softer donut washers seem to work in most cases, more so than the harder smaller ones that often come in the close-couple kit.
I've been coming across more of the 4 1/2'' ones lately, I think they're only found on ideal standard loos. I looked one up a while back and if I remember correctly they're ÂŁ6 each.
Luckily I have managed to re-seal the old ones I have come across so far. Although they're a rip off they do seem to be well made and keep their spring.
The 1.5" and 2" foam ones will seal on 99.9999% of WC's (i only don't say 100% as i believe - because i've seen pics -there are triangular ones out there? what on god's earth is the point of that..)
I bet if you put the doughnut in place and put the cistern on straight and level and get your mate to hold it in position, no c/c bolts, no screws to wall and flush it, it will never leak. Your job then is to keep it in that position, be that with spacers between tiles and cistern, be that leaving c/c bolts barely tight if a bad installation will force the cistern off level or off striahgt when tightened and so getting it solid by others means. That's the trick.
Reply to Donut washers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
