If the pump hasn't been run dry due to a frequently empty tank then it may be ok, could possibly be partly sticking solenoid, on my GX5 burner there is a very sharp distinct click when the solenoid is energised closed after the purge period. Maybe worth fitting a new nozzle and getting the pump pressures checked by someone before spending a fair bit of money.
[automerge]1590446119[/automerge]
One other item, on some of these modern burners I think that they are also fitted with a air intake shut off damper opened with a hydraulic ram by the pump pressure, might also worth checking this out in case its not opening fully and throttling the air.
