Discuss Does anyone know off the top of their heads... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Does the body of a clicker basin waste tend to be longer or shorter than the body of a pop-up (rod operated) waste?
Lol , both useless pal , I always use the "captive " type waste
( like a spinning disc )
Same length ish within 5mm
Had a few of them stick so you can't open them
Never had it myself TBH , but I can imagine a small piece of grit will cause problems . I always tell the cust to clean them with soap and water whilst spinning it. Worked up to press
1-2mm in it.
Never had a problem with the spinning ones only , the clicker ones which are a good source of income nowadays with changing them.
I have had problems with both but quite often is the customer at fault. Not clean, dental floss to name a few faults.
Reply to Does anyone know off the top of their heads... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
