SlowMoFlow
We have had problems with poor flow rates in newly-installed taps. Pressure was measured at 2.3 Bar at the kitchen tap.
The plumber has removed the Pressure Reducing Valve (rated at 2.1 Bar) which was fitted just after the main stopcock where the mains supply comes into the building. This has improved flow rates, but I'm concerned that now the building's plumbing is at full mains pressure, it might be putting too much stress on things like the boiler. We have a non-combi boiler and a hot water tank. No cold water tank in the building.
Should I be worried about this? Presumably the 2.1 Bar pressure reducing valve was installed for a reason.
