Discuss Distance between cold pipe cross over hot in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello
I need to cross over an existing copper hot water pipe with a cold 15mm mains copper pipe. Is there a standard I need to adhere to in terms of clearance?
Reply to Distance between cold pipe cross over hot in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone, How do you know if there is a cross over with the pluming system in flat? All pipe work under sink, bathroom etc in the flat itself...
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
Bungalow built in 2001. All copper pipework (water and heating) runs in channels of expanded foam polystyrene between a concrete floor and OSB...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering...
