Discuss Digital Radiator thermometer to balance radiator flow and return in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Marty32
Good morning
Could anyone advise on where to buy a sensibly priced digital thermometer with the clamps/clips to attach to the rads flow and return pipes to balance the radiators?
Thanks very much
Mart
Thanks Joshi - definitely not over the top as if you wanna do a sound job you want to have the right tools!
I mentioned this dual-channel thermometer a while back for balancing radiators. Some thought it was a bit OTT!
Dual Two Channel 2 K-Type Digital Thermometer Thermocouple Sensor 1300°C 2372°F | eBay
You can attach the thermocouple tips to the pipes with insulating tape.
The thermometer can display each temperature separately or you can use the difference function to make balancing easier. It also does Max, Min and Average.
Reply to Digital Radiator thermometer to balance radiator flow and return in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
