Discuss Coupler advice in the USA area at PlumbersForums.net
Hi
I'm an enthusiastic DIY-er, but stuck on something. Hoping someone can help. I have a cold water manifold which has a 3/4" BSP male thread at one end and a 3/4" female thread at the other (presumably so you can daisy-chain them). I need to put it into a 20mm pex al pex cold ring in my house - water flowing in one end and out of the other. Connecting the female end of the manifold is straightforward as I have 20mm pipe fittings that output to male 1/2" BSP, so I just need a 3/4" (male) to 1/2" (female) connector and then go into the 3/4" female end of the manifold. But please could someone help me work out what I need to fit the male 3/4" end of at the manifold to the same pipe connectors (i.e. the 20mm to 1/2" male).
In short - how do you connect 3/4" male to 1/2" male, please? I can't seem to find a 3/4" female to 1/2" female reducer. Thanks in advance.
Any chance of a picture of the manifold ?
If you want to use them then you can use this depending on which end your connecting to
The compression adapters will fit into them like normal
Brilliant - ta! Might also need them for something else. Appreciate the help.
Reply to Coupler advice in the USA area at PlumbersForums.net
In short: Do suppliers sometimes list BSPT as BSP? I need a tee, 22mm each end with a BSPT in the middle for an expansion vessel to dangle from...
A
Hi, I am replacing a kitchen tap and have run into some trouble when connecting the flexi hot and cold pipes to the hot and cold mains pipes. The...
Adam tl
A
Morning all. I hope this is the correct place for this post. If not i'll happily move it to another forum area. I am renovating a property and...
I am trying to source adaptors/reducers for the below taps for my renocation We have the tap ware currently but Union adaptors are needed to fit...
Deleted member 120897
Hi everyone - I have an old outside tap with male thread but struggling to find a right hosepipe connection after the other one broke. The top of...
