Discuss Coupler advice in the USA area at PlumbersForums.net
Hi
I'm an enthusiastic DIY-er, but stuck on something. Hoping someone can help. I have a cold water manifold which has a 3/4" BSP male thread at one end and a 3/4" female thread at the other (presumably so you can daisy-chain them). I need to put it into a 20mm pex al pex cold ring in my house - water flowing in one end and out of the other. Connecting the female end of the manifold is straightforward as I have 20mm pipe fittings that output to male 1/2" BSP, so I just need a 3/4" (male) to 1/2" (female) connector and then go into the 3/4" female end of the manifold. But please could someone help me work out what I need to fit the male 3/4" end of at the manifold to the same pipe connectors (i.e. the 20mm to 1/2" male).
In short - how do you connect 3/4" male to 1/2" male, please? I can't seem to find a 3/4" female to 1/2" female reducer. Thanks in advance.
Any chance of a picture of the manifold ?
If you want to use them then you can use this depending on which end your connecting to
The compression adapters will fit into them like normal
Brilliant - ta! Might also need them for something else. Appreciate the help.
Reply to Coupler advice in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
