Discuss Cost of replacement boiler - Quote required, near Stansted in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
JamesL85
I have a flat that currently has a central heating system with a gas boiler in the kitchen, an immersion cylinder in a cupboard and two water tanks in the loft; a large cold water tank and a smaller central heating expansion tank.
The coil in my immersion cylinder looks to have cracked, causing an overflow of the central heating expansion tank. I have had some fairly big quotes to replace the immersion cylinder. Bearing in mind my boiler is quite old, kettles badly and has a lack of user controls, I was interested in the cost of just replacing the whole system with a combi boiler.
I spoke to British Gas, but they cannot give me even a rough quote. They can send an engineer to write up a quote, but not for 6 weeks and I can't wait that long.
I know that the job can vary between properties, but roughly speaking what would be a good estimate for the following work:
- Disconnect and remove the old boiler.
- Disconnect and remove the immersion cylinder.
- Disconnect and remove the water tanks in the loft.
- Cost of a new combi boiler.
- Install a new combi boiler.
Many thanks,
James.
as above depending on your location in the uk but for a decent job using quality products and a nice warranty between £2500 and £3500
you can list your details here and a local to you plumber will help you out
[DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
Good ball park figures there. Where are you based as I'm know someone on here would be happy to pop over and give you a estimate.
You'll save yourself a few quid by disposing of the old boiler and tanks in the loft yourself.
Reply to Cost of replacement boiler - Quote required, near Stansted in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I seek some advice on replacing an existing regular boiler. I currently have an old Potterton 10-16 Netaheat electronic, which is around 35...
Hi All, what's the cost of a service for an unvented system ? (valiant boiler & mega flow cylinder). I was charged £320.00, for the following...
My daughter lives alone in a 3 bed semi in the west country. The house is 20 years old. The central heating and hot water are provided from a...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hi all, We're looking to update our existing central heating setup and wanted to get a few more opinions. We currently have an open vented...
1K
