Discuss copper pipe jointing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
cracking bits of kit fittings are dear and I have stopped using mine as much as I used to due to cost but great bits of kit!!
Like above, very good, bit not cheap.
ideal when you can't use a naked flame.
Rems, rigid,nova press , all good. Milwaukee now making one, but it's pricey.
Reply to copper pipe jointing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I have a condensate pipe that appears to be leaking at the joint. How do I fix the leak? Would something like plumbers putty around the...
Afternoon all, It appears my toilet inlet pipe has developed a leak at on of the top 2 joints (between plastic pipe into toilet and between...
Hi, I'm trying to connect 3/4" copper to 22mm copper in an old house. However it appears that the 3/4" is actually slightly smaller (measured at...
Looking to see what iron pipe part can fit a 10mm ball joint? In this pic there is a part that connects the ball joint (or whatever they are...
Hi, I wonder if I could have some advice please. I have a rental shepherds hut with an outdoor copper bath. I expect to close down for winter...
