Discuss Copper pipe for tub faucet loose in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Deleted member 120188
Hello, I had to removed my tub faucet yesterday and after removal I noticed that the copper pipe sticking out of the wall spins freely. It doesn't come out (I have not tried to pull with much force) but I am concerned the solder behind the wall is broken and it will leak. Am I way off with this assumption? To access behind I will have to destroy the large tile it comes through and am trying to figure it out before I go any further, any thoughts or options are welcome.
Thank you
It could be into a push fit connector, which spinning freely is normal. If it was on a soldered joint doing as you describe, it should be gushing out.
Reply to Copper pipe for tub faucet loose in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello All, I have an issue and hoping someone could shed some light on the problem. We have been getting a smell coming up in the bathroom...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
Hi, in order to replace the solenoid on my shower I need to take it off the wall (bad shower design). I've got all the electrics disconnected...
Hello, the edge of the end of my bathtub leaks when I am about 3 minutes in the shower. The faucet is on the opposite side. What could be causing...
