Discuss Consense lagging in the Central Heating Forum area at PlumbersForums.net
Would someone be able to confirm for me whether external condense runs now must be lagged including through the wall ?
32mm yes needs to be insulated 40mm no that’s fine
Reply to Consense lagging in the Central Heating Forum area at PlumbersForums.net
Our boiler is in the loft and I encountered a leak in a roof above our side extension store room which has transpired to be from the boiler...
I have a CH boiler installation with a nice simple vertical condensate drain, down and out through the wall to a pipe outside. All is as it...
We moved into a house with a gas Aga (I think converted from oil). The extraction pipe is fitted against and runs through an external wall, then...
Looking for silicone recommendations for sealing between a metal bath and upvc wall panels. I was going for dow 785+ but someone mentioned its no...
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
