Discuss CONCERN AROUND PLUMBING METHOD in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, my bathroom fitters installed this plastic pipe as a feed to the new radiator, i'm slight concerned because it is bent over the wooden beam and at a strange angle. We're having a tiled floor so i'd hate for a leak and have to rip up the tiles. Can anyone advise whether this should be cause for concern?
Thanks,
That is just poor workmanship. It may not leak, but if it was my bathroom I would want it properly aligned so that there is no strain on the “o” ring speed-fit style joints.
Obviously there is the risk that some one nails through the pipe if the floorboard is not clearly marked when it is reinstalled
Thank you Brambles. Am i within my rights to ask him to change it? I assume the correct method would be to drill through the beam and put a straight piece in?
He may not change it, but would express your concerns to them. I don’t see any reason why copper was not used when it has been on the other pipe? This would be able to overcome the issue, imo.
I wouldn’t like that under my floor , especially if its tiled . The pipe is fine but both elbows will be stressed and knowing them things they may decide to unscrew themselves.
The other pipe is copper because it was already there from the old radiator, it’s only the fact that the new radiator isn’t as wide that they’ve had to put that plastic piece in. Hopefully they will change it if I ask nicely!
Reply to CONCERN AROUND PLUMBING METHOD in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
Sonya K
