Discuss Concealed shower question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumbduff
Hi
Am I right in thinking that a concealed shower in only practical for fitting beneath plaster board in a stud wall and not on a solid breeze block outer wall because of the depth of the mixer assembly?
Then why do it ? When you can have a surface mounted one the pipework can be concealed
Personally I think the surface mounted showers can be better looking and not much more bulky than the "built in" type. The outlet for hose is part of shower, so no silly plumbing for that also. And easier to service or replace in the future.
Definitely easier to service as well to change in case you've got an issue with the shower valve. The pita would be taking off tiles without having the same ones ... and not such big risk of a leak I side the wall
Reply to Concealed shower question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
Hi All, I am looking to take my bath out and fit a shower. Regards to tanking. Is it ok to just seal everything with plastic rather than just paint tanking slurry? Thanks in anticipation, best regards Staggers
Hi All, Looking for some advice on my little bathroom project. I took the bath out. I got a shower jacuzzi thing. The base has 2 wheels in the corner. Do I assemble the unit first attach water and elec, and slide the very heavy unit in on the two wheels? Or do I get the base in the corner and...
