1bit
As you know I have been doing some plumbing and started soldering for the first time, Iam pleased to announce that all my soldered joints were spot on and didnt have one leak
I have come across a new problem though, this is the 4th radiator I have installed in the house (along with many compression fittings) and one of the valves compression fitting just keeps leaking? I have tried everything, less PTFE, more PTFE, PTFE arpund the olive and end of pipe lol... I even replaced the section of pipe so I could put a new olive on and result was the same, I have re-fitted the new section 3 times (previous one 5 times) and can not stop it leaking? - the threads are fine, theres no damage and no dirt in the threads either? I normally apply PTFE around the threads in correct direction (clockwise) about 3-4 times around the threads...all other valves & compression elbows/couplers have been fine? - with this I have tried no less than 3 and tried much more..several times.
I have noticed that all other valves seem to tighten in manner that the Nut is circa 4mm from the base of the threads, but on this one it gets almost 1-2mm from the base - its screwing much further in that the others?
the water is definitely coming from the threads and not any other part of the valve or from the back of the nut.
Can anyone offer up advice for this? I mean Im gunna keep having to replace the bit pipe so can put new olive on and that requires melting solder to get it free!
thanks
thanks
