Discuss combination cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
johnpb
Hi, I have a combination cylinder in small holiday home, the water storage tank fills up quite slowly which sometimes causes it to run out while using the power shower. How can I speed up the flow? is it as straight forward as replacing the ball valve or can anyone suggest how to sought it out?
Fortic/combination cylinders are not designed to be used with a pumped outlet due to the low cws.
wattsie1987 is spot on, no where near enough cold water storage for a pumped shower in a combi cylinder, the mains will not be able to keep up with the flow rate coming out of the shower!
You could try putting a low pressure seating in the ball valve, it may improve matters.
Reply to combination cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Hi, am getting our bathroom updated and local company suggested ditching our traditional attic CW tank/vented cylinder and pump for the shower and...
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single...
Hi, I have a hot water cylinder which feeds 3 outlets (kitchen sink, basin in bathroom & bathtap) which has never had very good pressure (probably...
I had my indirect hot water cylinder removed a few days ago and the central heating boiler and pump is turned off at the fuse spur right next to...
