Discuss Cold water tank replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all,
I have an old galvanised metal cold water tank that needs replacing, I've purchased a cistern plastic tank replacement and was recently quoted £1,600 for a 2 day labour + pipe materials.
The old metal pipes we have are of odd sizes so I was told this would require special tools to remove. Please see attached images.
I would greatly appreciate any expert advice regarding the costs as I did not expect it to be this high.
Many thanks!
Sounds about right if they were supplying everything
800-1k in labour and about 400 in materials including the tank
If you don't mind how much were you expecting ?
Hi Shaun,
I've already paid for the new water tank.
So the £1,600 quote covers labour and pipe materials (materials estimated to be around £100)
I was told on inspection it would've taken a full day to complete, so I was expecting precisely what you estimated, £800-1k.
But now I've been quoted 2 days worth of work, so £1,600 fee.
Thanks for the quick reply.
The only thing I can suggest is get another quote but tell them one of it's services is in steel pipe
Sounds like Dick Turpin has made a comeback , get a couple more quotes / estimates .
Agree with tfj get quotes.
Also no special tools required other than maybe an angle grinder, also I would make sure all the valves are replaced and if me would have the steel cut out as far back as possible and new copper pipework after that point.
PS. All in all much the same replies as on the other forum here.
And maybe threading equipment for the steel pipe out from the tank
Convert steel to copper from beneath and treat it like any other plastic tank.
Hope it comes apart and doesn't snap :D
  • Creative
Reactions: rpm
Reply to Cold water tank replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
For reasons that I won't go into. Is it possible to control the water flow to a cold water header tank without having a ballcock in the header...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
Hi, We have a large Heatrea Sadia unvented hot water tank, not sure of the size in liters but its about 1600mm tall. The tank is around 3 years...
I live in an apartment and have a cold water tank in it. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I...
Morning. I have a leak. It’s coming from the connector pipe….the picture shows the pipe. It is a cold water pipe going in to the back of my...
