Discuss Cold mains water hammer when taps are turn ON? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The cold mains is in 22mm copper on a pipe run to to a bath and basin taps next to each other. The mains water is 4 bar static, no PRV or check valves. The bang happens seconds after the cold tap is turned on at either the cold bath or basin tap. There is a 0.5 litre potable water expansion vessel about 4 metres away prior to a combi boiler. There is a mechanical water hammer arrester 6 metres away close to the mains water stopcock. Don't want a PRV due to installation difficulties and the filter servicing required (very hard water). Given this, any ideas on the best way to resolve this please?
Clip all pipes correctly and lag them anywhere they are touching anything
It's impossible to reach the pipe to clip at one section (an elbow joint). Do you know if a mechanical water hammer arrester, such as the Altecnic 525040, installed a few metres upstream would resolve this?
The shock arrestor should be fitted with a pressure reducing valve just after the internal srltop tap, or just after the first branch to allow full pressure at the first outlet (usually kitchen sink)
Altecnic also do a pressure reducing valve with a pressure gauge cheap as chips from plumb center or pts
Thanks for the replies. Do pressure reducing valves require maintenance in a very hard water area?
Which make and model of adjustable pressure reducing valve is the most reliable, ideally fit and forget?
I don't mind pay out the extra for the reliability.
Thanks for the suggestion. I read the instructions for the Caleffi PRV here:
caleffi.com/sites/default/files/file/581035.09.pdf
Unfortunately, the instructions state the PRV cartridge needs cleaning at least every 12 months and a water hammer arrestor should be installed close by to prevent risk of damaging the PRV! Might be working perfectly for the first few years but several years later without being maintained, who knows. Does anyone know of a PRV that does not need to be maintained please? I believe there are some about but can't remember the manufacture name.
There isn't one
Reply to Cold mains water hammer when taps are turn ON? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I've got water hammer issues with my cold feed and some with the hot feed. When the cold sink tap, cold bath tap and thermostatic shower in the main bathroom is opened and closed there are hammering sounds from the living room ceiling. It sounds like knocking. There's no hammering whilst...
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom floor when the cold feed for the loo turned off/ same with the washing machine. So I turned off the mains water supply. Opened the highest tap first...
Hi everyone I have been a plumber for 3 years now, I haven't come across many issues with water hammer so I'm not to sure what to do. it happens on the hot pipework, more specifically the hot taps in the bathroom (basin and bath). but it only seems to happen when I open the hot tap to a...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution I could see. I'm in Brisbane, Australia but I'm after general ideas from anyone here or in UK (I realise this is a UK based site). Point form...
T
I'm getting water hammer in three cold water taps when turning on. If hot water is also turned on there is no water hammer. Previously I was getting all sorts of noises from the pipes even when no taps were turned on. I ran all the hot water from the hot water system via the hot water tap...
2K
