Discuss coal fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
thats what i want to know is the pipe like pot liners that make the chimney from builders opening to terminal,would you class this as a class 1 chimneyAs long as its over 180mm its class 1 and ok for solid fuel
your prob right regarding the size,i had a quick look and exaggerated the size,as you do,.nearer 9inch and defo glazed liners,i'm not doing the job just passing on info,whats the best way to go about tranforming builders opening,would you use chair brick etc.I can't see it being a 12" liner. Afaik you don't get one but i may be wrong. Most brick chimneys are 9" x 9". Modern chimneys are lined with precast or salt glazed liners of 8 or 9" daimeter. If you are not sure get someone in to check at the customers expense.
Reply to coal fire in the Plumbing Jobs | The Job-board area at PlumbersForums.net
