Discuss Cloakroom toilet fit out in the USA area at PlumbersForums.net
Looking to fit wall hung basin with a bottle trap fitting going into the wall on the wall below. I need to run a waste pipe between the waste adaptor (40mm)(pic below) in the ground into the wall to connect to the bottle trap. I am looking to use 21.5 mm pipes as i wont have much room in the wall. Can someone help me pick the the exact pipe fittings that i will need for this job? And would you also know if i can replace the waste adaptor from 40mm to 32mm sized one easily?
Thanks a lot for your help
Easy enough to get either a new adaptor or a 40mm x 32mm reducer. You must run the waste in 32mm anything smaller will not do! Chop chase in wall if need .
Can’t use overflow pipe for a basin
Thanks you both for your help, how difficult would i be to replace the current in the ground waste adaptor (40mm) with an 32mm one? I can't seem to be able to move it as its fitted firmly in cement.
I am looking at this product below for it, is there something better i could use that i could hopefully source from toolstation or screwfix as both nearby?
This is a 32 40 reducer (solvent weld) available at screwfix. I think your only option is to drop waste pipe vertically on surface of wall, then box in, or use a sink cabinet which would allow space for moving things left and right.
That’s a cap end eg
need to carefully chip around the perimeter and then use a chisel or flat screwdriver all around to raise it up
hardest part is getting it started
Reply to Cloakroom toilet fit out in the USA area at PlumbersForums.net
hi, as the title suggests i need help finding this type of toilet seat, i ordered one but completely forgot to check distance between fittings and...
A few years ago I installed a wall hung toilet pan in my last house which did not flush well when disposing of waste solids. The water would rise...
Looking for advice please, our plumber has left us in it and I think I may know why. So they where supposed to be fitting a cloakroom sink...
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
I’m fitting a small basin on a floating countertop (30x40cm) and will be chasing the internal clinker block wall to around 100mm wide to accept a...
