Discuss Central heating system drained, leaks repaired and now gushing flowing noises in radiators and pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes the system was quiet til 2 new TRVs were fitted in the lounge
If you open the TRVs fully (anticlockwise) or as suggested in #4, remove the heads, the system should be as it was before. If there's still a problem it sounds (literally!) like something else has been done, which the plumber isn't telling you about. If he's not prepared to come back and look at a system he's worked on I'd question his competence.
Hi again. All the rads th
Do me a favour matey. Put the heating on and check to see if the side with the trv on gets hot first or the other side. You may have done this already?
Hi again. All the rads that have TRVs fitted warm up at the TRV end first, except one radiator in the lounge. On this radiator, the TRV has been moved from one side to the other (it might also have been replaced). I've attached a photo! I believe this is the only rad in the lounge (of 3 rads) that had a TRV fitted when my new boiler was installed 3 years ago. Sorry I'm relying a lot on memory! The reason I know for sure that the TRV has been moved from one end to the other is because I have an old photo with that rad in it!
On my quite old Honeywell TRVs they must be installed vertically on the flow, horizontally on the return. Don't know if yours are same, but if fitted wrong it might have something to do with it. But if it's wide open it shouldn't affect anything (in theory).
It's fixed!! The mains water supply was off yesterday as maintenance was being carried out in the area. I don't know whether this has anything to do with my issues. Anyway when the water supply came back on I took your advice and bled the radiators again. I got air out of the kitchen radiator! I put the heating on and it was a lot quieter. I bled the radiators again and now it is back to normal and the rads and pipes are quiet. I've checked it this morning and it's fine. I can't thank you all enough. Not only did you give me advice, but you never let me feel I was alone with the problem. You really are amazing!
Well done! Glad to hear
You’re welcome
Get the plumber back sounds like it could be air in the system are there any automatic air vents installed on the flow and return pipes could also be cheap Trvs
The OP posted it is fixed, would you like to the be the plumber called back on a Saturday only to find it is fixed!!! :mad:
Well done you , we like happy stories and it cost you no more dosh . UKPF rules Rob Foster aka centralheatking
Ha! But of course in my case I tried to resolve the issue myself, I rang the plumber, he wasn't interested in helping me, he said he would phone me to arrange to come around and I gave him a week to phone me back but he didn't. It's you guys on this plumbers forum who gave me advice and support and who sorted my problem for me and I'm SO grateful. Thanks again!
Hi to all.I have problem again with my heating.My bolier is making a sound like a popcorn maker but very loud popcorn maker machine.I had a blockage in pipes and aparently plumber sorted it...yes for 1 week.yesterday popcorn come back and they change motorised valve,pump,valves under and behinde the pump flushed the system and it was ok but like i say for 1 week.What could be the problem?
I suggest you repost this as a new thread it might get lost below a solved problem
Hi Melany, your problem has been posted under my thread and it would be better for you to post it as a new thread. Good luck with your problem. I realyy do hope you're able to sort it soon.
Reply to Central heating system drained, leaks repaired and now gushing flowing noises in radiators and pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
