Discuss Central heating on all the time in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, sorry this is a very amateur question. I know next to nothing on plumbing...but if anybody can offer any advice that would be great...
I've just moved house where I had a lovely combi boiler fitted after living with storage heaters and immersion tank. The house I have moved into has a very effective oil boiler but as it's not a combi I'm a bit unsure how it works.
What I would like to know is, if I have the programmer turned ON all day with the heating thermostat set to the desired level, will the hot water constantly be heated. Sorry this may be a stupid question I'm just concerned that it will be costing me a fortune. The manual for the programmer (horstmann centaurplus c17) indicates that once the tank is at a set temperature it SHOULD turn off (although I appreciate the moment it drops temp it will need to heat up again). I know this will probably cost me more to run but just considering options for how best to maintain a good temperature in the house.
Thanks in advance folks.
if it is a combi then the hot water only heats when the tap is turned on.
Thanks for the reply.
Sorry don't think I was very clear. It's not a combi (we moved from a house with a combi) We have an immersion tank that is heated when the programmer is on (or at least thats how I understand it).
Its more a case of if I have the programmer set to be on all day. It's not going to be constantly heating the water is it? But it will try to maintain the temperature in the tank?
No. When the heating and water get to temp they will both go off and when the temp of both drops the boiler will come back on to reheat.
Reply to Central heating on all the time in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Hello its my 1st post hope im in the right place We brought a new house a medium-large 3 bedroom semi, we moved in the summer. Now coming to winter we started putting the central heating on. The central heating has a mind of its on it’s really strange iv never experienced this We put the heating...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
I am repiping my whole house and changing from combi boiler to a 30kW system boiler & 250Ltr or 300Ltr unvented indirect hw tank. Can somebody give advice on my rough plans/sketches for repiping my radiators using 22mm & 15mm. I have only shown the flow line as the return line will just be a...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any kind of instructions/manual and therefore trying to figure out ourselves. We have what looks like a boiler/water tank system (coming from a standard...
