Discuss CDI Compact. Wiring loom, loose wire with block what's it for? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Hi guys went and piped up a compact CDI today, first day doing one of these and was impressed with it. Was having a nosy around it because i'll be back there Monday to finish off the install. There was a block with 2 blue wires coming out of it that was hanging loose and i couldn't see another connector block that it should be plugged in to and i couldn't find anything in the manual. It cable tied up with the main loom if that helps.
Maybe it has just come loose from a component but i didn't see anything obvious. Any ideas? long shot I know.
Thanks.
There is always a couple of extra blocks hanging about in worcesters.
I've noticed them when servicing not sure what they do though, it might be a universal loom.
I haven't noticed any spare blocks on worcesters before. Hopefully this thread jogs someones memory and they know.
If it is the little blue connector block then it doesn't connect to anything, I have been fitting a lot of the si compacts and its the same on them.
mfgs so it doesn't connect to anything for certain, you know this?
I wouldn't worry about it. if it is missing from its home it can't be a million miles away.
Like I said before there is always spare plugs I'm Worcester boilers.
Power her up and you will soon know.
Reply to CDI Compact. Wiring loom, loose wire with block what's it for? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
