Discuss Cast iron 21/2 inch access pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Anna D
This is a brand new pipe, but the access plate can't tighten as the bolt thread seems to be miscast. Any remedy or should I get co back?
Call them back as it`s brand new. There is a remedy but why should it cost you to make good?
Thank you, will do. Out of interest what is the remedy, so I can check it with what they offer.
Either replace the bolts if the threads are damaged which is unlikely, use shorter bolts if they are going into a blind hole and touching the bottom or some people will use a thicker gasket if there is one which is ok as long as it seals or re thread the holes.
Reply to Cast iron 21/2 inch access pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
We have 2 brand new cordless, battery powered press tools in stock, and flying off the shelves. Our TekTools TZ1930 & TZ1550 are packed with...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
PSxxxxxx
