Discuss Can't unscrew pressure relief valve prv, combi boiler, please help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pad04
Hello there, would be very grateful to get some help on my copper pipe dilemma.
With reference to the attached image, when unscrewing the valve (to be replaced with a new non-leaking one), the male pipe (on the right hand side) it is screwed on to rotates as well as if the two are stuck together.
There is some sort of sediment in the fine crack between the two which I have tried to scrape out, however this doesn't seem to be helping.
Would be great to know if there is another way of going about this, especially as its the only thing getting in the way of installing a new valve and having a boiler that doesn't lose pressure!
Any questions, please ask. Many thanks in advance!
are you gas safe reg?
I doubt it too.
What you're doing is illegal. Call a gsr in because you're more than likely barking up the wrong tree anyway.
Reply to Can't unscrew pressure relief valve prv, combi boiler, please help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a...
Pritesh Patel
Hi everyone, Just wanted some confirmation regarding a PRV fitted to the mains supply in my building. All 6 flats in the building are now...
I have a "Firebird Envirogreen Condensing Combi Oil Boiler 26kW" a part has went and I can't find it anywhere, I was at every plumbers merchant...
M
I have a viessman vitodens 222F combi storage boiler on the ground floor. It has 100l capacity inbuilt cylinder which is delivered on mains...
Max Hill
M
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
