Discuss Can you buy Soldered Isolation Valves? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jonjack
I can't seem to find Solder ring /Pre-soldered isolation valves anywhere so presume they don't exist or are generally not stocked by any of the main dealers since demand is so low.
I've extended a hot/cold water supply from upstairs for a small downstairs bathroom and have been using soldered joints - I didn't really want to put a compression fitting valve (these seem to be available) in the line when everything else I have done is soldered.
Can anyone tell me if/where they can be bought online, if at all?
cheers
Jon
dont forget to dismantle it before soldering or it wont work again
nothing wrong with compression, and often a good reason to use compression.
I agree, compression, if it's a stop valve it's going to be accessible (should be).
Reply to Can you buy Soldered Isolation Valves? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
