Discuss can drill tap holes ina steel bath without damaging the enamel. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
julesverne
Just pulled out bath cust has bought and no tap holes.Not seen this before every steel bath i have fitted has always had them. Whats the best way to put tap holes withiut damaging the enamel.
Thanks in advance of replies
Try Richard at *********?
I have done it in the past using a spring punch to create a start, and then just tape and patience and a tight sphincter.
But it's been a while.
Diamond would probably cut the enamel OK then you could switch to bimetal and take it very carefully. Best of luck though as once cut it will rust if not very well protected.
BTW make up a holder in plywood for the bimetal as you won't have a pilot. The 365 drill have a guide but fear this won't be man enough for the bimetal.
Just use a 6/7mm hss bit for a pilot hole and then use a bi metal hole saw. About 28mm I think. A new bit will do it easy enough.
Same thought pattern . Lenox do diamond grit cutter will go through both. Be really carful not to heat metal as will blister enamel also clap timber to back of bath to prevent burst through and distortion.
im with dan just use a pilot drill first use a bit of masking tape to stop the bit slipping maybe even startb with a 2 mm hole then open it up to the sixe of the hole saw pilot
Reply to can drill tap holes ina steel bath without damaging the enamel. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone I have been a plumber for 3 years now, I haven't come across many issues with water hammer so I'm not to sure what to do. it happens...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
1K
I have just had a new boiler and 210 ltr unvented tank fitted in the loft to replace a very old Baxi back boiler. I have now fitted a Solic 200...
T
Hi, I'm having a new bathroom installed and having issues getting the right bath/shower set up. Shower has to be over bath as no space for a...
3K
