Discuss Can anyone recommend me a decent 800 quad enclosure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
All the sub £400 ones I have fitted are all much of a muchness, haven't fitted many high end ones to compare
Can't see the point of shelling out silly money as it's usually only the rollers that wear and these can be replaced quite easily and cheaply
If my patch was South Kensington and not South Wales, I may play a different tune
Kudos or matki are the best I've seen and fitted not cheap though
Reply to Can anyone recommend me a decent 800 quad enclosure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have holes in the wall of my shower enclosure. Down low at the open corner, between the quartz wall and the solid pan. Same at each end of the...
Hello there all, I care for my disabled mum and her wet room ceiling has developed small speckles of black mould. I plan to remove the black...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Can anyone recommend a toilet, sink plunger. It’s not something I do a lot of, but it will be handy to carry on the van, for when needed. Don’t...
