Discuss Can anyone recommend me a decent 800 quad enclosure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Something that should last.
All the sub £400 ones I have fitted are all much of a muchness, haven't fitted many high end ones to compare
Can't see the point of shelling out silly money as it's usually only the rollers that wear and these can be replaced quite easily and cheaply
If my patch was South Kensington and not South Wales, I may play a different tune
Kudos or matki are the best I've seen and fitted not cheap though
Reply to Can anyone recommend me a decent 800 quad enclosure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
