Discuss Built in gas cooker and hob connections in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi .Hoping someone can help .Is there such a thing as a double micro-point self sealing valve to plumb in hob and oven without having to use T pieces and ad another micro-point .
Also the hob is over the cooker .Would a metal braided hose be safe too use or does it have to be fixed pipe work ?
Thanks Chris
No there isnt also hob should be hard piped really
Also you can’t do the pipework yourself need to get a gas safe engy in
Thanks .Not intending to do work myself .Just trying to get an idea of cost/work involved .Hope you don't mind me asking .The single point I have at the moment would be about an inch away from the back of the oven .Would this need moving as well. Thanks again Chris
Again my friend you will not get gas related answers please read the forum rules. You say you will not do it yourself. That may well be true however the next person to come along and read this thread may well think it sounds easy. Best advice is get three engineers out to quote you
No apologies necessarywe’re happy to help even if that’s just pointing someone in the right direction. Cheers
Reply to Built in gas cooker and hob connections in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon. I got a new Mapress gas installation in my catering business. All end points are 1/2" the main tubing is 32mm. Some appliances...
Hi, We're changing our old electric range cooker for (hopefully) a dual fuel (electric oven/gas hob) range cooker. We have a pantry room directly...
2K
Hi, We are designing and building cooking gas bottles with electronics controlled valves. These are for kids camping chalets. Its purely a...
2K
I have a new kitchen fit and the gas man just connected the hob and oven (both bayonet fittings low down). There is quite bit of the oven flexible...
7K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
