Discuss breakdown and repairs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jack.frost
What's the best way to learn to do breakdown and repairs? Any recommendations?
I was thinking that, a few companies offer courses.. What would I do if I took a job and couldn't fix it though? Would make me look like a right amateur and lose future custom
Be logical, methodical, start with the basics and just be honest with your customer 'Never worked on this particular model before, but i'll give it a go'
As others have said just get on as many courses as you can and hit the books, learn how to use a multimeter properly
AW cheers forya help , I'm used to installs want to get into breakdowns, ..any recommendations on make /model of multi metres? And yes gas work ,
a risk you run ! have an engineer to fall back on who can attend with you after :)
will cost you at first but in the long run you'll learn more !!
Good ideha may av2 get sum1 on speed dial...
Do you think British gas would let me go with one of their engineers if I work for free? Sounds like a long shot but maybe one of u lot know something /someone I don't .
Boiler technical services are always your friend (mostly)
a good deal of info on here for common problems and we all share experience. Is all hidden in the gas forum tho which you will have to apply to get into. It's worth it tho,there is a wealth of experience in there.
Good luck mate.
New posts
Reply to breakdown and repairs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days...
