Discuss Brass "Faringdon" lockshield valves leaking in the Central Heating Forum area at PlumbersForums.net
I have just tried to balance my heating system (16 cast iron rads, 3 towel rails), all the lockshields were fully open. When I try to close them down, they all leak, from a dribble to a gush. When I say all, I tried 6 and then stopped. The system was installed 9 years ago. Despite extensive googling, I cannot find anything to say if/ how they can be repaired. The lockshield is not the traditional type, it has an inset screw that is adjusted with an allen key. I am assumming that there is some type of rubber olive that has perished. Can anyone advise if/how I might be able to fix this. The installer has long since retired, so I cannot speak with them.
To aid identification, the attached photos show: the TRV, lockshield, lockshield with cover/cap removed.
I think that type of valve is made / imported by West Radiators:
the data sheet shows how they are assembled:
Try contacting West and see if they know about this problem and can supply replacement seals or cartridges. If you've got six valves all failing in the same way at the same time it seems likely that it was a manufacturing fault. Perhaps the o-ring material was incorrect or the seatings were ground too deep.
Also supplied by Supplies4heat
And at eye watering prices by The radiator company .
I would suspect Italian imports as that's where 2 above company's source there rads.
Reply to Brass "Faringdon" lockshield valves leaking in the Central Heating Forum area at PlumbersForums.net
Rad is leaking from TRV valve, seems to be seeping out of where the pin comes up. I tried tightening up the nut below the pin, but that didn't...
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
Heating system is 14 years old. On inspection I find that every lockshield valve is fully open. After adjusting some, I find that they weep...
Hi I have a Greenstar 24i Junior combi boiler and a central heating system with a radiator in the bathroom, living room, dining room/kitchen and...
2K
Hi, I have a leak on the live side of one of my rads, in the GF loo. Its a condensing combi system, the house is only 5 years old, so fairly new...
