Discuss Brass connectors with "serrated" threads (why?) in the USA area at PlumbersForums.net
I've been buying parts for a water purification system and notice that some of the brass fittings with external threads (they are size G25 = 1") have regular serrations on them.
Here are a couple of pictures...
Other fittings I see available do not have these features....
I've searched and searched but find no explanation of the serrations.
I'm a bit concerned about their effect on tape I intend to use for sealing them into other components.
Has anyone seen this before and know what it is for?
it's because the fittings are used in other countries where they still use hemp and paste. The threads are roughed up to stop the hemp from slipping when you tighten the fitting.
In France, hemp and paste is the norm, and if we buy fittings that haven't had the threads roughed up then we have to do it ourselves with a hacksaw blade.
Thanks! I did wonder whether it could be that kind of reason.
So my question is whether it will be ok to use tape, or will it shred the tape and cause the joint to leak?
I scratch the threads for ANY thread-sealed fitting so think you will be absolutely fine with tape. You need plenty of turns, but you'd need plenty of turns even without the serrated threads. Serrated threads is usually a sign of quality.
Why not just use loctite 55 ? So much better than ptfe!
Is it?
I've used tape a bit but never the glue type sealants - just sounds a bit messy; and I've heard tape is easier to clean off if you have to re-do a joint.
I did order one of these in case I needed it...
It's not loctite 55 but I guess it will do the same job.
Loctite 577 is liquid
Loxeal sounds the same as 577 - "anaerobic" so it goes off when o2 is excluded i.e. inside the threads.
577 is awesome btw 👌
Thanks!
I was wondering what could possibly initiate the hardening - especially as it says "anaerobic".
You mention exclusion of O2, but how is inside the threads any different from inside the plastic container it is stored in?
Thanks!
I searched myself and found....
"LOCTITE® threadlockers cure in the absence of air and presence of metal ions."
So the metal plays a part as well.
There is a list of "inactive" metals where a primer is recommended but brass and copper are amongst the active ones, so no primer needed.
Reply to Brass connectors with "serrated" threads (why?) in the USA area at PlumbersForums.net
In short: Do suppliers sometimes list BSPT as BSP? I need a tee, 22mm each end with a BSPT in the middle for an expansion vessel to dangle from...
Where the black polyethelene service line enters this particular structure is by far the most freeze-prone area. The structure is an elevated...
I understand that, at least in the USA, the term "Lead Free" means "not more than a weighted average of 0.25% lead when used with respect to the...
Hi, I'm installing a water filter which has plastic inlet and outlet fittings like this... The suggested way is to go straight to flexible...
2K
Hi, Trying to locate a straight version of this angled adapter/reducer for a shower. The (cheap) shower came with these angled ones (see...
