Discuss Boost entire gravity hot at cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Phil
As part of an upcoming bathroom job my customer has bought a Stuart Turner monsoon 2.0 bar single pump to boost the gravity hot for the taps.I've fitted loads of shower pumps but never one for taps, I've downloaded the instructions and on one of the diagrams it more or less shows the pump fitted straight off the top of the cylinder outlet, eg cut the pipe, feed it through the pump and connect back.Showers run straight from combi, yes combi its a strange set up in this house, the pump will on't really be feeding the Bath hot, kitchen hot and basin hot.
If I have read the post right, I'd be careful pumping from a combi.
Depending on the flow switch type you may cause problems.
Speak to the Boiler MF's before doing it.
Apologies in advance if I've misunderstood you phil
Yes, I wasn't going to mention the combi in case it confused things, this is a normal bog standard airing cupboard with a copper cylinder and loft tank, the combi jut heats it and supplys mains hot to the other part of the house.
I would fit it this way
Install an s flange / if cylinder has secondary hot water tapping at top you can use this
Install pump off pump connection and out of pump to hot house
Top connection off s flange / cylinder if using secondary tapping for vent
Problem I could see if using a t in the hot out it could draw air in from vent
Check size of header tank as well to make sure it doesn't run dry, especially if a combi is running at same time as bath filling.
Reply to Boost entire gravity hot at cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single one-bedroom flat. The mains pipe bringing water into my top-floor flat is 15mm copper pipe. There is a water meter in the flat and a stop valve. There is...
Hi, I have a hot water cylinder which feeds 3 outlets (kitchen sink, basin in bathroom & bathtap) which has never had very good pressure (probably because of the set-up) but last year got so feeble that a guy suggested fitting a pump alongside the cylinder. This can work fine but then all of a...
1K
I have a negative head twin impeller Stuart Turner pump feeding hot and cold to three showers, one bath, plus hot to three basin's from my gravity fed, loft cold water tank and airing cupboard hot water tank. Occasionally the pump operates for a couple of seconds without demand for water. More...
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions about this below. I had intended to reuse the cold water tank and the cylinder sitting underneath it but my plumber suggested I replace the cylinder as...
We need an urgent advice, we have a gravity water system and we are in a middle of loft conversion. We are adding an en-suit in loft and prefer to have a good water pressure there. What we want, is to either be able to run multiple showers at once, or if one person is having a shower, other...
1K
