Discuss Boiler syphon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Beemer
Looking at the syphon on my daughter's Worcester Combi I see many particles at the bottom. Should the syphon be emptied and refilled at regular intervals to remove these? Are these particles a normal fallout from the condensation process?
Beemer
Should only really need to be removed and cleaned by GSR on yearly service.
Particles are probably from the casting process for the heat exchanger as it is aluminium on the Worcester combi. Most likely just sand.
or the aluminum heat exchanger falling apart
I asked because the divertor valve or its motor had jammed. I freed it with a couple of taps from my screwdriver handle. Perhaps some particles were to blame.
Ian
Reply to Boiler syphon in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Boiler is losing pressure, from 1.5 bar to 0 bar in about 4 hours. Have checked all rads and seem to be fine, no water out external prv...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
Hiya - posting in this forum as I'm guessing this relates to my neighbour above's boiler, but I may be wrong so please say if so. Basically the...
I have a Worcester Bosch Greenstar 15i condenser boiler which is about 13 years old. There is a separate hot water tank. Recently the fan in the...
Hi, I have a few issues with my bath drainage and leaking. The first issue is that the near corner of the bath by the taps is sloped downwards...
