Discuss boiler restarting is it the pump faulty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
mickytwohammers
sorry forgot what i should do micky2h here
Wilo pump RS15 when central bleed screw is removed lots of water shoots out
rather than a dribble does this mean impeller is not spinning boiler is restarting every 30 seconds
G/S 217929
§/COLOR]
any clues please
They generally gush water out when the bearing seals have gone.
Check for electric supply first, if you have voltage and you can't make it start with a small screwdriver in the shaft. I'm afraid it's had it.
thanks pump is running i.e. power etc
but gush water seals might be gone i was wondering if blocked or impeller loose might cause access water from front and hence boiler restarting
Might not mean the pumps gone, Iv noticed some shoot out more water than others...
Ravenheat CSI about 9 years old it keeps starting turning off on all works but not as it should be
i thought pump maybe not be working propely
Ravenheat csi is a combi isn't it? So you've removed the boiler casing to access the pump?..
yes the case was has to be off
the pump is not leaking wth bleed screw in but boiler still restarting
just wondered why so much water if it was a clue to problem
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
Please read the forum rules.
Kind regards.
Reply to boiler restarting is it the pump faulty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
