Discuss Boiler Input-Output Efficiency Calculations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Damon Apple
Hi guys,
I am choosing to install in my project homework a worcestor-bosch 15i System boiler and i need to work out the
Input, Output and efficiency workings out on all settings.
I am totally stuck even after worcestor technical team sent me the installation data brochure but i just cant work it out.
This is what I am doing Max Rated Output=15kw
Max Rated Input=15.4kw
So i assumed output divided by input x 100 = 97.4% Gross efficiency and if i divide this by 1.11 i get the Net efficiency of 87.75%.
Now heres the problem worcestor bosch claim this has an efficiency of 90.1%
What am i doing wrong?
Link attached for the installation brochure instructions table etc...
http://www.worcester-bosch.co.uk/ca...r-i-system--manufactured--aug-09---jan-11.pdf
Any help very much appreciated :mad2:
Nothing!
The efficiency figure in the manual is the "SAP2005 Seasonal Efficiency", which is calculated by a fairly complicated formula designed to simulate the usage of the boiler over a year. This has now been replaced by the "SAP2009 Annual Efficiency" which, for the 15i is 88.8%. You can read about this at http://www.sedbuk.com
<br>
This is what I am doing Max Rated Output=15kw<br>
Max Rated Input=15.4kw<br>
<br>
So i assumed output divided by input x 100 = 97.4% Gross efficiency and if i divide this by 1.11 i get the Net efficiency of 87.75%.<br>
<br>
Now heres the problem worcestor bosch claim this has an efficiency of 90.1%<br>
<br>
Nothing!
The efficiency figure in the manual is the "SAP2005 Seasonal Efficiency", which is calculated by a fairly complicated formula designed to simulate the usage of the boiler over a year. This has now been replaced by the "SAP2009 Annual Efficiency" which, for the 15i is 88.8%. You can read about this at Sedbuk
Reply to Boiler Input-Output Efficiency Calculations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, My home is 2 storey - split into 2no zones. 14 rads downstairs and 7 upstairs. Open vent system standard boiler. Hot water is immersion...
2K
V
  • Locked
Hi,I had a Worcester Bosch Greenstar Junior 24i installed 5/6 monthsback but the boiler has to be set to max to get enough heat aroundthe house...
vansbeat
V
  • Locked
I have been trying to decide on what boiler to go for - I think my head is about to explode - but I have to make a decision. Some background - I...
8K
M
  • Locked
Hello All, First Time Poster on this forum and would appreciate some advice on a new S Plan Plus System Im looking to have installed next week...
4K
happyflyer
H
M
  • Locked
Hi all i have been searching the internet for advice on choosing the right boiler for my needs. i was looking at Worcester Bosch as I have...
2K
