Discuss Boiler fault finding book in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Matt0029
Any one got any recommendations, for a boiler fault finding book for a newly qualified gas engineer wanting to learn more about boiler break downs. Thanks.
Mr combi fault finding book
If you want a PDF version just shout
I know this is probably old fashioned and boring but I always think you're better off putting the effort into understanding how things work. That way, the answer seems more obvious to you when something is not working. Does that make sense?
will find the mr combi in a bit
  • Fault Finding Fan Flued Combination Boilers.pdf
Did you manage to open file ? tried on laptop and on phone no joy
Matt
Send us your email via pm and will get it over to you
Reply to Boiler fault finding book in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one ....just easy to use and reliable. The fluke 115 looks good but its above my budget. My current socket and see one was great but it's developed a fault.
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
