Discuss Boiler Cupboard in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Richo106
Hi
I have a logic plus combo boiler C35 and I'm going to be building a plasterboard cupboard around it..does need minimum clearances around it? and some form of ventilation e.g louvres vents?
Ive look in my manual but cant see to find any info
All advice appreciated
The manual will definitely have minimum clearances in it
At least 4" all around and yes always best to have some airflow
But bigger the better
Minumum clearences are in the manual bud here is info from it regarding ventilation
Reply to Boiler Cupboard in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a 40 year old floor standing Glow Worm 45-60 boiler (open vent )which is in a cupboard in the centre of the house. Its an old workhouse and has been working without issue until now. The pilot light went out and now wont relight. It lights but as soon as you release the button it goes...
Hi I seek some advice on replacing an existing regular boiler. I currently have an old Potterton 10-16 Netaheat electronic, which is around 35 years old and still working OK. It is fitted to a std 'Y' plan system with boiler in utility room and separate hot water tank, pump, valve etc in...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler. Initially we thought the boiler may stay in place but after discussions with the builder we would have to move the boiler to replace the floor and...
Hi, I've got a leak coming from the loft into a bedroom which I think is caused by water overflow from feed and expansion cistern (see attached one of the photos when I found out the cistern overflowing above the overflow pipe) and one other pipe that has a small drops coming out of it that is...
2K
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a Worcester greenstar danesmoor 18/25 oil boiler. Covers 10 radiators mostly large double panels, some towel rails and smaller rads too, as well as an...
2K
